Revit 2023: How to sketch the ceiling of a level in multiple parts?
JamaL9722060
Message 1 of 10
JamaL9722060
For example, in the screenshot below, I wanted the ceiling of level 1 to be composed of 3 parts such that their areas appear separately in the takeoff schedule.
How this can be performed knowing that the Revit doesn’t accept the lines of the ceiling to intersect?
Why the does Revit consider the ceiling as one block?
Jamal Numan
Replies (9)
Message 2 of 10
Model 3 separate ceilings.
Message 3 of 10
syman2000
Remove these lines
Afterward you create another ceiling filling in the middle portion.
Message 4 of 10
JamaL9722060
I remove the indicated lines and sketched the one in the middle but never worked with me. What I might need to consider?
Jamal Numan
Message 5 of 10
syman2000
You are on the right step. However don't edit the existing two ceilings. Instead create new ceiling and draw the middle portion of the ceiling. Once you done that, your schedule should appear 3 ceilings
Message 6 of 10
SteveKStafford
On the off chance you've missed this, I'll add, when the ceiling tool is active notice the option to Sketch Ceiling vs Automatic Ceiling.
Automatic Ceiling will create a ceiling that fits within the nearest available boundaries while Sketch Ceiling will require you to draw each boundary. If you want three ceilings then either create one automatic ceiling, then edit the sketch. Copy/Paste the ceiling in the same place and Edit that ceiling's sketch, repeat for the third.
I'd just create a ceiling using Sketch instead and repeat two more times until I have three ceilings, as desired.
Steve Stafford
Message 7 of 10
JamaL9722060
The reason I start editing before sketching other portions of the ceiling is to have a clue where I am, as if I don’t then I got no idea where are the already sketched ceilings.
What could be the best practice to manage this situation? To sketch the ceiling but still to see the already sketched ones
Jamal Numan
Message 8 of 10
syman2000
Floor plan will only show floor element that cut according to the cut plane. If you set your view range the above 2.6m, then the ceiling will show. Instead of messing up your floor plan view range, I would use ceiling plan instead.
Message 9 of 10
anze.kumar
Or create a Ceiling Plan.. which is different than Floor Plans as the Orientation of the view is "up" instead of "down".
So if you create a ceiling plan in the middle of your Floor it will look up and you will see the ceiling. In this case you don't need to adjust View Range of floor plan to be above the ceiling and beneath the floor slab/roof.
Message 10 of 10
JamaL9722060
Thank you very much for the help. It works fine
Jamal Numan
