Revit 2023: How to display the XY coordinates?
JamaL9722060
Message 1 of 8
JamaL9722060
Jamal Numan
Replies (7)
Message 2 of 8
Use Spot Coordinates.
Message 3 of 8
SteveKStafford
If you want to display coordinates like shown in the map then you'll have to be able to know/provide the coordinates to Revit. That's either through importing a survey and using Acquire Coordinates or if you know what the intended coordinates are for some location on the building you can use Specify Coordinates at Point.
Then you can use Spot Coordinates annotation to display coordinates relative to the site's coordinates.
Steve Stafford
Message 4 of 8
JamaL9722060
What I meant here is just to display the coordinates in Revit the same way they appear in AutoCAD as per the screenshot below
Jamal Numan
Message 5 of 8
You can't.  That is the coordinates of the crosshair in AutoCAD.  There is no such thing in Revit.
Message 6 of 8
syman2000
You can use spot coordinate and will report your XY. However I rarely use this because building can have arbitrary XY.
Message 7 of 8
SteveKStafford
Revit doesn't display coordinates as you move around but you can use Report Shared Coordinates anytime. Select the tool, click on a point and it will tell what the coordinates are. But as @syman2000 wrote, unless you define shared coordinates those coordinates may be meaningless.
Steve Stafford
Message 8 of 8
JamaL9722060
Jamal Numan
