Revit 2023 Family Library
JP-HNA
Message 1 of 11
JP-HNA
I just upgraded from Revit 2021 to 2023, and I can’t find the family content library.  Please advise me where they are.
Thanks!
Replies (10)
Message 2 of 11
jvpantin2
Download from here:
https://knowledge.autodesk.com/support/revit/downloads/caas/downloads/content/autodesk-revit-2023-co...
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
Message 3 of 11
jvpantin2
If you mean file location in your PC, must be here:
C:\ProgramData\Autodesk\RVT 2020\Libraries\US Metric (or default language)
Message 4 of 11
Keep in mind that you can upgrade your earlier version content as well.
FWIW: you can also load content from the cloud.
Video: Load Autodesk Family | Revit 2023 | Autodesk Knowledge Network
Message 5 of 11
suaad.bailey
I have downloaded the content but am unable to view or load it in Revit and it's very frustrating, are there any videos on how to do it?
Message 6 of 11
RSomppi
Did you read message #3?
Message 7 of 11
huerta.daf
Community Visitor
Community Visitor
when I go to the autodesk page to try to download the family libraries, the page tells me that this product is not found, could you please help me, I already have revit installed
Message 8 of 11
catherineawitt
I'm in the same boat. I just installed RevitLT 2023 and can't find families.
When I look for the files through file explorer: C:\Program Files\Autodesk\Revit LT 2023\en-US
I reach FamilyRes.dll, and no .rfa files.
When I use filepath in Explorer mentioned in Message 3: C:\ProgramData\Autodesk\RVT 2023\Libraries\US Imperial
my computer can't find it.
In Revit, when I search under Component --> Mode --> Load families, the folder is empty under filepath
C:\Program Files\Autodesk\Revit LT 2023\Templates\English-Imperial
When I download, install, and restart revit with English content file from the link in Message 2,
the all of the above - through File Explorer and through Revit Load Family - happens the same.
So far, Forum and Autodesk answers have not led to a solution.
Message 9 of 11
gary.mccune1
Hi Catherine,
I too struggled until I noticed that I was looking in the C:\Program Files folder instead of the hidden file C:\ProgramData.
Here is the procedure to unhide it:
Open File Explorer from the taskbar. Select View > Options > Change folder and search options. Select the View tab and, in Advanced settings, select Show hidden files, folders, and drives and OK.
Message 10 of 11
amarildo_clash
Community Visitor
Community Visitor
revit 2023
Message 11 of 11
155873
Community Visitor
Community Visitor
Oh God sent you 😄 I had the same problem with libraries and folder, files were just hidden. Thank you
