Import images
Import images
ksullivanS9B4Z
Import images
ksullivanS9B4Z
REVit lt 2022
Import Image- returns a window with these lines
Failed to open
file path
Any thoughts?
Sounds like a local issue. Maybe related to folder permissions?
...Can you open it okay outside of Revit?  Also, what's the file extension?
Can you see the images opening the folder using Windows File Explorer?  If so, try drag and drop the image from that folder onto your Revit view or sheet window.
