Solved by ronsarlo. Go to Solution.
Solved by curtisridenour. Go to Solution.
Solved by Lachlan-JWP. Go to Solution.
Maybe desktop scaling? Set it to 100%.
Thanks for the suggestion.
I'm running a 3x monitor setup at home and office.
I've set all 3 to 100% display scale and tried changing around the primary monitor.
No change. The width bug is still there.
Is there any other ideas? This is so weird.
What are the screen resolution of each monitor at your home setup?
I had a similar problem a while ago where Windows 10 Pro comes with Arial Narrow pre-installed but Windows 10 Pro for Workstations does not.
Check that both machines have the same font installed.
Amazing! That did the trick!
Thank you so much! @Lachlan-JWP @curtisridenour
I had no idea my 10 Pro didn't come with Arial Narrow.
