Solved by ronsarlo. Go to Solution.
Solved by curtisridenour. Go to Solution.
Solved by Lachlan-JWP. Go to Solution.
Thanks for the suggestion.
I'm running a 3x monitor setup at home and office.
I've set all 3 to 100% display scale and tried changing around the primary monitor.
No change. The width bug is still there.
Is there any other ideas? This is so weird.
I had a similar problem a while ago where Windows 10 Pro comes with Arial Narrow pre-installed but Windows 10 Pro for Workstations does not.
Check that both machines have the same font installed.
Amazing! That did the trick!
Thank you so much! @Lachlan-JWP @curtisridenour
I had no idea my 10 Pro didn't come with Arial Narrow.
