Revit 2022 on Win 11 Home
jkobarchitects_com_au
Message 1 of 8
Has anyone had any issues running Revit 2022 on Win 11 Home? Do I need to upgrade to Pro?
Cheers,
J
Replies (7)
Message 2 of 8
RobDraw
What kind of issues?
What makes you think that they are OS related?
Rob
Message 3 of 8
Apparently only Windows Pro and Windows Enterprise are listed under Revit system requirements. I am about to buy a laptop that comes with Win 11 home and was wondering if I will have to upgrade to Pro for Revit to work.
J
Message 4 of 8
I can't speak for Windows 11 Home but I have been using multiple Revit versions in Windows 10 Home without any issues.  So if you are working by yourself then I wouldn't be worried. But if you use the laptop in a corporate environment then Pro is recommended.
Message 6 of 8
This is good question, @jkobarchitects_com_au.  Autodesk doesn't make mention of Win 11 Home.  You ought to contact Autodesk directly about this by opening a Support Case through your Account Portal.
Post here what they tell you. It'll help others who have the same question.
Option B would be to contact your Autodesk Reseller. They should know.
Message 7 of 8
Thanks, I will contact Autodesk
Message 8 of 8
That's the response...
