The path of travel was working for the previous versions of Revit. I see at some point in 2022 there has been an update to Path Of Travel. Now it isn't working for me. I've checked the wall heights, door openings and all of the exclusions, unfortunately the path of travel runs straight through EVERYTHING. Has anyone else run into this problem? When I select the Reveal Obstacles icon, It doesn't highlight any doors or walls. My walls are 12 ft high.
Can someone assist me with this issue?
Post your file.
...maybe phasing related? If the obstacles don't actually exist in the View Phase, they won't act as obstacles.
Thanks.
I figured it out. I checked my Route Analysis Settings and I guess when it updated, the software checked every box including walls, doors, furniture and windows. Therefore, nothing was considered an obstacle. When I unchecked them, and updated the path, then it worked perfectly.
