Merhabalar, Revit 2021 'i bugün kurdum, Precast menüsü yok. Nedeni nedir acaba. Teşekkürler .
Solved by teodorb. Go to Solution.
Merhaba @enestamturk, Autodesk forumuna hoş geldiniz!
Prekast menüsü Revit için Yapısal Prekast Eklentisinden gelir ve bu Revit ile kurulmaz. Bu yüzden kurulumdan sonra Prekast menüsünü görmezsiniz.
Ayrıca, bu uzantı 2021 sürümü için henüz yayımlanmamıştır. Yayımlanan eklentilerin listesi için aşağıdaki makaleye bakın: Released Revit 2021 Updates & Add-ins
Translation: Hello, I installed Revit 2021 today, there is no Precast menu. What is the reason? Thanks
Hello @enestamturk, welcome to the Autodesk forum!
The Precast menu comes from the Structural Precast Extension for Revit, and this is not installed with Revit. This is why you would not see the Precast menu after installing.
Additionally, this extension has not yet been released for the 2021 version. For a list of released add-ins, see the following article: Released Revit 2021 Updates & Add-ins
mine was installed with Revit 2021 see screenshot below
according to the help this was integrated into 2021
The former Structural Precast Extension for Revit is now integrated into Revit with a dedicated Precast ribbon tab, located next to the Steel tab. The precast features are available with the native Revit installation, simplifying their deployment and making them available in all languages supported by Revit
DarrenP
@DarrenP Thank you for catching this. When I was looking for the Precast tab on my 2021 version, I was expecting it to be further to the right and didn’t see it next to Systems. Updating the 2021 released add-ins article now.
@enestamturk Regarding the missing Precast add-in, since it is now built in, it should be loading from the following folder: C:\Program Files\Autodesk\Revit 2021\AddIns\Precast
If the Addin file exists in the folder above, there may be a problem with reading the digital signature. Can you attach a journal file (this should record info about how this is loaded when Revit opens)?
@enestamturk have you been able to confirm that the precast addin file exists in the program files folder?
We have confirmed that with the OS region and language settings set to Turkey, the Precast addin fails to load regardless of what language Revit starts with. If you change the OS region and language settings back to US then the addin should load as expected.
Can you please validate this?
Kind regards,
Another workaround would be to change the GUI folder found at this location
