columns for text layout
2 ANTWORTEN 2
Nachricht 1 von 3
wisedrawing
1729 Aufrufe, 2 Antworten
How do I put columns into my text box, split the text into columns just like word or ACAD does?
so far I either just get info back on structural columns or that you can't do it??
would seem strange such a simple text set out is not available
cheers
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: wisedrawing
Text in Revit is not the greatest, but then it's not a text editor.  The BIM idea is to generally avoid text, and use smart text, such as schedules, keynotes and tags.
Let us know what you're trying to do.  There is more than likely a built in solution for what you're trying to achieve.
Nachricht 3 von 3
hmunsell
you cant... at least not like in Word or AutoCAD does.
you may be able to use a Key Schedule to do it though. not the easiest to edit, but it will keep items lined up.
Howard Munsell
