Revit 2021 makes a lot of noise when using material browser
RECArchi
Message 1 of 9
RECArchi
Hi everyone,
In some of our computers, when we use material browser, Revit is working well (not slow at all) but fans begin to ventilate very fast and it makes a lot of noise. Otherwise in Revit, everything is normal, thus problem seems to be related to material browser only.
Moreover, if we do exactly the same manipulation in material browser on other computers, Revit is OK and ventilation is normal.
This problem is not related to Revit Plugins because I moved the folder containing all plugins (to unload them at the start of Revit) and problem is still there.
Did anyone ever face this issue? If yes, how did you solve this problem ?
Computer concerned :
Manufacturer:  Dell Inc.Model:  Precision 3630 TowerSKU:  0871Memory:  16 GBProcessor:   Intel Xeon E-2274G CPU @ 4.00GHzMotherboard:  Dell Inc. 0Y2K8N
Graphics:  Intel(R) UHD Graphics P630 1 GB
 Microsoft Remote Display Adapter
 NVIDIA Quadro P2200 4 GB
Thank you in advance.
Sincerely.
Replies (8)
Message 2 of 9
rmoore1
Changing the View type in the Material Browser to Text View solved that for our Dell boxes
Message 3 of 9
pendean
Community Legend
Community Legend
Forgive me, I'm curious about what your expectations are: your car makes a lot of fan noise when it is heated up vs when it is cool too for example, as do Computer fans, they come on when the demands on the hardware affect the heat build-up inside the box: it's a cause-and-effect type issue. Do you just need to invest in quieter fans or move/relocate/reorient your boxes to not be so distracted by the noise?
Or change your workflow as noted above.
Message 4 of 9
I think you are experiencing this issue.  It did tax the CPU.
Slowly refreshing material thumbnails while opening the material browser in Revit 2021 | Revit 2021 ...
Message 5 of 9
rmoore1
For us it was the Dell machines, didn't happen on other boxes or older Dells. Revit 2019 and 2020. Sounded like an airplane taking off
Message 6 of 9
RECArchi
Thank you for your replies.
@rmoore1 : Your workflow (changing the View type in the Material Browser to Text View) works well for now, our airplaine-computers do not take off anymore ! As you mentionned, only newer DELL computers are concerned by this issue. Do you know what is the technical origin of this problem?
@pendean : What are my expectations ? Understand what is going on. Material browser is not something that seems to consume resources (for me). And the fact that old DELL computers are not concerned is strange.
For now, we will use @rmoore1 's trick. Thank you again for this workflow 😄
Sincerely.
Message 7 of 9
pendean
Community Legend
Community Legend
@RECArchi Got it: now you know, it's normal, contact Dell Support for new vs old behavior and why, in the meantime place your desktops in a location or position so the fans are not so distracting but still within earshot so you know what is going on.
Message 8 of 9
RDAOU
@RECArchi
How new are the newer DELLs? Try install the the older Direct X legacy package from Microsoft. https://www.microsoft.com/en-us/download/details.aspx?id=8109
Message 9 of 9
RECArchi
@RDAOU : Bought less than 1 year - description mentioned in my first post.
Sincerely.
