Hi All,
Is there a way to wrap text in elevation mark, so that my sheet number could fit inside the bubble? Thanks
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
@Anonymous
It doesn't work....even though I have adjusted the text box width but the text still doesn't wrap.
post your family so we can check? thanks
have you try to uncheck wrap between parameters only as suggested by @RDAOU ? thanks
Yes, I have unchecked. Please see attached. Thanks ![]()
It works!but is there a solution that does not need the space in between? As once I added a space in between the sheet number on my title block would change to 2 rows too.
have you try to change the width of your text to fit in bubble? thanks
@Anonymous wrote:It works!but is there a solution that does not need the space in between? As once I added a space in between the sheet number on my title block would change to 2 rows too.
@Anonymous
