- Mute
- Permalink
- Report
Hello everyone,
I really hope, that I get any help or comments to my problem...
First of all it’s important to say – this topic is not about the IFC export bug that was reported here:
https://forums.autodesk.com/t5/revit-architecture-forum/ifc-export-issue-revit-2021/td-p/9438686
Here is the small prehistory:
In the last two projects in RVT2020 we used the IFC Add-in from Autodesk (IFC 2020) and struggled with errors in the exported PSets (some instance parameters for windows were not exported in a PSet, I reported about this last year). It took me so long to understand that the problem was with the IFC Add-in... A few months ago I finally discovered that and got a clean model in IFC with a full PSet for all of windows in our project just using the native Revit 2020 IFC Export.
Last week we installed Revit 2021. I didnt install the IFC Add-in (IFC 2021), because I knew, that it's already caused problems in the previous version.
And what I've got? I got the same problems with the PSet or rather with the instance parameters of windows exporting the IFC from the NATIVE Revit 2021 IFC Exporter.
Here are two screenschots with the same PSet file. As you can see, in RVT2020 we had all of the windows parameters under "CG-Attribute". In RVT2021 its not more the same.
Is there anything about 2021 (in spite of bugs reports about the missing PSets from last year?), that I dont know?
We have the last updated version of RVT2021, where all the mentioned bugs should be solved...
Thank you in advance for any, any help!..
