Hi!
the only information that I found about my problem:
I would be very grateful if someone had experience with it and could share it.
So, the problem is, that we use the Pset for IFC export and for some elements (90% - windows) only type parameters are transferred to the Pset, although:
1. The instance parameters are exported for the same families of the same type;
2. The solution with separate PropertySets for I (Instance) and T (Type) does not work.
The example of a PropertySet:
#Windows
PropertySet: CG_Attribute I IfcWindow
Geschosszugehörigkeit Text Ebene
Typ Text Beschreibung
Rohbauhöhe [m] Length Höhe
Rohbaubreite [m] Length Breite
Umbaustatus Text Kommentare
Feuerwiderstand Text Feuerwiderstand
The instance parameters are hier "Geschosszugehörigkeit", "Umbaustatus" and "Feuerwiderstand".
For IFC export we use the "improved" IFC add-on:
https://apps.autodesk.com/RVT/en/Detail/Index?id=8986482933300179260&appLang=en&os=Win64
Thanks in advance for any help,
Anastasia.
Gelöst! Gehe zur Lösung
Gelöst von TripleM-Dev.net. Gehe zur Lösung
#Windows
not sure if I got it right, but is your PropertySet file set to have IFC property name on the left and the name of the Revit parameters on the right?
Thank you for the question Anastasia (@borcheva)!
I’m not quite clear on the behavior you are seeing, could you reply with:
@Mirko.Jurcevic is correct:
# Format:
# PropertySet: <Pset Name> I[nstance]/T[ype] <element list separated by ','>
# <Property Name 1> <Data type> <[opt] Revit parameter name, if different from IFC>
# <Property Name 2> <Data type> <[opt] Revit parameter name, if different from IFC>
So using the Revit parameter first is only "allowed" if the exporting parameter should be the same name, otherwise the exported IFC name comes first, follewed by datatype and then the Actual parametername in revit.
- Michel
Hi, thanks for the answer!
Sorry, I should have described from the beginning hier - on the left are IFC parameters, on the right are Revit parameters.
I dont have any problems with it actually - I become all the parameters in the ifc modell. The problem is, that a few e.g. Windows get only type parameters exported, and not instance parameters.
Hi, as I've already @Mirko.Jurcevic answered:
Could you post the file or at least with 2 windows, on that does export and one that doesn't and the Pset file.
If you isolate a window that doesn't export instance values and only export that one to IFC, does the IFC still lack the instance parameters? or is it more random affect windows. (maybe audit the file and/or check warnings?)
Also, does it miss all instance values or only the ones defined in the Pset?
- Michel
Hi!
Thank you for your ideas and thoughts on my problem.
The first thing I tried is just exporting the isolated windows (they all then had the instance parameters!). Then I exported other next elements and came up with an idea what the problem is. Namely, on the connected/joined walls in Revit. If these are joined, the instance parameters aren't exported in some randomly selected windows.
I've attached 2 screencasts, just to understand what I mean.
The only thing I have to adjust hier is the dividing line in the elevation views. But I'll handle that.
Thanks a lot!
