Revit 2020 - Keynote schedule issue
4 REPLIES 4
keith_hansell
294 Views, 4 Replies
Hello - We have a running list of user keynotes that are separated by two types: Demolition Keynotes, and Remodel Keynotes.
I would like these to populate into the same schedule, with the demolition keynotes appearing first and the remodel keynotes appearing after the entire demolition list.
The demolition keynotes are alphanumeric and start with a "D".   D1, D2, D3, etc.
the remodel keynotes are numeric: 1, 2, 3, 4, etc.
Is there a way to accomplish this in Revit 2020? If we let the schedule run as normal, the numberic (remodel) keynotes appear before the demolition (opposite of what I want). Thanks in advance!
Labels (2)
4 REPLIES 4
can't you get there by sorting/grouping ascending/descending?
Lachlan-JWP
in reply to: keith_hansell
Is there a reason you can't use two schedules?
keith_hansell
in reply to: Lachlan-JWP
Yes, this ended up being what I did...just thought there may be a more simple solution.
This didn't work. If I reverse sorted, the numbers would be descending order.
Forma Design Contest
