Revit 2020 has no Site Plan in the project browser
Message 1 of 9
Hi. Once I start a new project in Revit 2020, under floor plans in the project browser there is only Level 1 listed. There is no Site Plan. Is it a new feature of Revit 2020? How can I make a Site Plan view. Thanks.
Replies (8)
Message 2 of 9
loboarch
Sounds like you are starting without a template maybe?  I would check to see if the templates installed and you are using one to create a new project.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 3 of 9
Hi. That was right. I start without a template. Do I have to reinstall Revit, or there is an easier way?
Message 4 of 9
Lakshman01
Hi, no need to reinstall the Revit, Install only the Revit Content Libraries. Use this Link
Message 5 of 9
...maybe not in a Project?
If you are in a Project, You can create a Site Plan View by going to View=>Plan Views=>Floor Plan, untick "Do Not Duplicate Exist Views" and select Level 1 to create a Site Plan from. Then set your desired View Range -- maybe something like this:
Message 6 of 9
Hi. I download & extract @ the desired location (C/ Program Data/Autodesk/Revit 2020) but still when I start a new project there is no Architetural, Construction, Mechanical or Structural template.
Message 7 of 9
Hi. Yes, but what would be the view range of the Site Plan, because only in the Site Plan you can work with the Topography.
Message 8 of 9
That is not true.  Where did you get that idea?  Do what I described and turn on the Topography Categories in the View.
Message 9 of 9
Go to Options=>File Locations.  Press "Help".
