Viewport Re-Size
Viewport Re-Size
Viewport Re-Size
hi there,
Would appreciate if anyone could outline the steps to change the size of this Viewport.  I am in Sheet View and the viewport is overhanging.  Is there a way to click and pull to resize?  I tried change height/ width but doesnt seem to work.  Should I work in Sheet View or Elevation View?
Thanks alot
constantin.stroescu
You have to do it from View, but you can activate the View directly from Sheet:
  • on Sheet View, click on the View you want to adjust the Crop value
  • either click mouse right button >Activate View
  • or from ribbon >Viewport >Activate View
  • now you can adjust the Crop
  • once finished, click mouse right button >Dectivate View
Constantin Stroescu
constantin.stroescu
the Viewport border itself follows the maximum extents of your cropped drawing. If you have Datum items (Grid,Levels ) or Reference Planes that exceed the Crop dimensions , they will be also incorporated inside Viewport bord....So, adjust them...
Constantin Stroescu
bill_gilliss
It is easy to see that the Sea Level level is what is pushing the extents of the view out to the right. Select it and drag its right-end grip to align with the others.
