Revit 2020 bug - nested labels don't work inside legends
10 REPLIES 10
Message 1 of 11
ldonkle
1016 Views, 10 Replies
See attached image... inside my Legends, the "Legend Components" with nested labels don't work when printing.
The label text all goes off in the middle of the legend
10 REPLIES 10
Message 2 of 11
ryan.duell
in reply to: ldonkle
Thank you for reporting this issue.  We are able to reproduce the behavior as described; I created an issue and my team will be reviewing it further.
Ryan Duell
Message 3 of 11
ryan.duell
While this issue is being investigated, it does appear that printing with Raster Processing has the correct result (nested labels do not shift on print.)  If you try that print setting with your dataset are you seeing the same result?  Thanks.
Ryan Duell
Message 4 of 11
ldonkle
in reply to: ryan.duell
Yes, that does work - legends look fine when I raster print.  (though the rest of the set looks "different" due to raster printing) But that's a good workaround, thanks
Message 5 of 11
ryan.duell
Just to update this thread, we are currently planning to resolve this behavior in a future Revit update.  In the meantime, raster processing can be used to print any affected views (containing legend components of families with nested generic annotation labels) as expected.  Thank you again for the report.
Ryan Duell
Message 6 of 11
eadamsonTES
Ryan, any idea on when that update will be released?
Message 7 of 11
ldonkle
in reply to: eadamsonTES
I too would like to know
Message 8 of 11
andrewTSS
It's been 3 months. Can we expect an update for this?
Printing a drawing set to raster is a terrible option when you've got multiple sheets and large drawing sets
Message 9 of 11
RobDraw
in reply to: andrewTSS
As stated above, stay tuned for a future update.
Rob
Message 10 of 11
ldonkle
this seems to be fixed in Revit 2020.1
Message 11 of 11
ryan.duell
Thank you for the update.  Yes, a resolution for this issue was included in the 2020.1 update.  Please reference the following release note:
Fixed as issue where nested generic annotations in a legend component shift location when printed with vector processing.
Revit 2020.1 Release Notes
Thanks again!
Ryan Duell
Forma Design Contest
