Revit 2019 won't let me add new Levels
Message 1 of 9
Does anyone have any Ideal why Revit 2019 won't let me add new Levels?
I have tried everything I know " Elevation TAB and Level button is Grayed " even if I open a new project.
Replies (8)
Message 2 of 9
Are you in a section or elevation view?
Message 3 of 9
Elevation View is Grayed out, as well as Datum.
Message 4 of 9
@Anonymous wrote:
... " Elevation TAB and Level button is Grayed " even if I open a new project.
Tab grayed out because it isn't the current View.  Level tool grayed out because one cannot be placed in the current View.
Double-Click on the grayed-out "Elevation" TAB, and then type "LL" and draw Level.
Message 5 of 9
Viveka_CD
Hi @Anonymous
I see that you are a new visitor! Welcome to the Autodesk forum community!
Please see how to create levels in Revit 2019
Let me know if the recommendations by the experts @barthbradley and @ToanDN help with your issue?
Message 6 of 9
You need to go to Elevations (East/West...) then you can be able to create level.
Message 7 of 9
I'm in elevation:Right but i can't add any levels
Message 8 of 9
ennujozlagam
check in the properties if there is a assigned view template and set to none and see if helps. thanks
Message 9 of 9
You are still in a 3D view, Right is just the view facing right. Open an elevation from the browser.
