I am using Etransmit of Revit 2018 and the transmit button doesn't show up. Can anyone help for this problem?
Same problem. etransmit button missing from etransmit dialog box in Revit 2020.
Looks like the bottom transmit model button is missing. You want to reinstall the plugin and install Windows Update.
Check the screen Display resolution of your monitor. I've seen this happen when the Display resolution is set too high,
