Revit 2019 tabbed views reducing docked window size
Alan.johnson1970
Advisor Advisor
Alan.johnson1970
Revit 2019.2 new project opens and the tabbed view reduces docked window size down right hand side.
I have had this issue before but it seamed to just go away.
Start project and docked window is reduced in size
Need to resize the docked window on the right hand side every time
My colleague is experiencing the exact same issue so I know its not just me.
AJ.
Alan.johnson1970
There must be others that have seen this issue??
AJ.
RobDraw
Have you tried searching for this issue? I've seen a number of posts regarding it.
Rob
Alan.johnson1970
Yes I have, and found nothing
AJ.
RobDraw
My work is done here:
https://forums.autodesk.com/t5/revit-architecture-forum/revit-2019-tabbed-views/td-p/8197992
Rob
Alan.johnson1970
Thanks but that just links to my post of the almost the same issue i had last year.
This is slightly different as it happens when you start a project,  the issue before was caused by the rebar browser.
AJ.
RobDraw
https://www.revitforum.org/architecture-general-revit-questions/40351-width-properties-project-brows...
There were some pretty major changes to the interface so I would expect some bugs to show up for some setups. Like your other issue, play around a bit to see if it gets resolved. If not, hope that it gets fixed with the next update.
Rob
