is there a way to vertically copy RC walls already filled with rebar!? I have a situation where with four identical stories.
Regards!
Gelöst! Gehe zur Lösung
Gelöst von Mohamed.Hesham.afifi. Gehe zur Lösung
Hi @Anonymous ,
Did you try this ?
1- Select your RC walls with rebars
2- From modify tab select copy from clipboard ribbon ( number 1 in attached images )
3- From modify tab also select the drop-down of paste from clipboard ribbon ( number 2 in attached images )
4- Select Aligned to selected level and choose your levels ( number 3 in attached images )
Ok that's it
, If you find this helpful , kindly like and accept as solution
You can also make a multistory stair
Method and steps are right here :
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
regards !
