Revit 2019 Tabbed views
Alan.johnson1970
Advisor Advisor
Message 1 of 9
Alan.johnson1970
I did see a post on this a while ago but i don't think it really get resolved.
With say Project Browser docked down the right hand side, everything is fine but then at some point it changes and the browser is all squashed up.
As yet I cant put my finger on when, or why this is happening, or what sequence of clicks, commands but its not just opening and closing views.
Just wondered if any one else has seen this issue.
AJ.
Replies (8)
Message 2 of 9
Viveka_CD
Hi @Alan.johnson1970
Do you have a multiple monitor setup (extended displays + another PC ), seamless connections?
Is so, what are their resolutions?
Have you checked your graphics card compatibility and for any recent driver updates form the manufacturer's website?
Message 3 of 9
aRcHiTeCt.JM
...do you mean Stacking Properties and Project Browser Palettes
https://knowledge.autodesk.com/support/revit-products/getting-started/caas/screencast/Main/Details/a...
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 4 of 9
Alan.johnson1970
I do have multiple monitors but this issue also happens on single screen.
A colleague has noticed this issue, so I know its not just my screen set up.
AJ.
Message 5 of 9
jayhar
We've seen this when a company had changed their drag and drop pixel tolerance size... Any chance that the case where you work?
or
https://www.tenforums.com/tutorials/...y-windows.html
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 6 of 9
Alan.johnson1970
I do not think this issue is graphics card or display related.
It is definitely something to do with the docked window and the tabbed views.
It doesn't happen all the time either, I can go days before it will happen.
AJ.
Message 7 of 9
Alan.johnson1970
Just an update if anyone was interested and has or comes across this same issue.
After playing around I discovered one thing that does cause the issue I was having.
With Project Browser docked to the right hand side, If I were to place Rebar in a concrete element, when the Rebar Shape Browser appears it was docking right next to the PB and in doing so it reduced the size of the PB. Once the rebar was placed or the tool cancelled the PB was still squashed up.
I have tweaked the position of the Rebar Browser and it seams to have fixed my Issue.
AJ.
Message 8 of 9
Viveka_CD
Thanks for coming back and sharing the update.
That's weird, shouldn't be happening with a rebar tool, may the UI folks can help iron out this issue if we are able to reproduce this on our end.  A screencast and journal from you also would help to investigate further. Thanks for reporting!
Message 9 of 9
Alan.johnson1970
