Revit 2019 shuts down when opening certain views
Message 1 of 33
Do anyone share the same problem as I, that Revit 2019 shuts down all the time without warning, whem I try to open certain views?
Replies (32)
Message 2 of 33
Avaris.
There are a lot of factors that can make Revit shut down unexpectedly:
1) Check Revit 2019 System Requirements
2) Check Certified Hardware
3) Please make sure the computer has more than 5 GB of available disk space and at least 4 GB of RAM.
4) Update Graphic Card drivers
5) Is Revit updated (Last Service Pack)?
6) If you disable Add-ins that are installed into Revit, does it still crash?
7) Try to disable Hardware Accelerator
If nothing helps, can you tell us more about the crash?
- Is the issue specific to a particular project?
- Is the issue specific to a particular workstation?
- Is the issue specific to a particular view?
- Is the issue specific to a linked file?
I'm quite sure @Viveka_CD can help you if you send her your journal files.
Message 3 of 33
Viveka_CD
Hi @Anonymous
Can you send me a recent journal and also check if you have the latest updates installed for your Revit version?
Thanks for the alert @Avaris.
Message 4 of 33
I have attached some journals from today.
My version of Revit is 2019.1
Message 5 of 33
Are you using Revit central files on Dropbox?  That could be a big issue.
The other is your model has been upgraded since 2015...there has been lots of changes since then, so you may have some funky glitches still hiding.
Also...what kind of connection are you using?  Are you in office or working remote?
Message 6 of 33
We are working on central files true Revit Server 2019, and in office, not remote.
Message 7 of 33
If your R:\ drive is connected to directly to a Dropbox share.... Move the files to the Revit Server and link from there.  Looks like Revit is sending a display crash after that link.
Message 8 of 33
P93mahapatra
Hiii...!!!
Reinstall the software again and then may be you will get problem solved,  check the Graphical Hardware requirements in the download page. Some times due to that software get crash again and again, low graphical hardware.
Message 9 of 33
Viveka_CD
Hi @Anonymous
Just following up on this issue. did any of the recommendations help?
Can you share files and additional diagnostic data?
See : https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Let me know if you have questions on the above.
Please share in a private link or I'll send you one.
Message 10 of 33
Hi @Viveka_CD
None of the recommendations have solved the problem.
Can you send me a link so i can try to share some diagnostic data.
Message 11 of 33
Viveka_CD
Hi @Anonymous
I've sent you a private upload folder.
Let me know if you can access the folder and when you upload the files.
Message 12 of 33
bberggren
We are experiencing this on our first Revit 2019 project.  Only certain views, not all the time.
We re-created the views, deleted original and the new views will still crash Revit sometimes.
Message 13 of 33
Viveka_CD
@bberggren
Looks like there is something else causing this behavior.
Does this occur with add-ins disabled?
Can you share a journal to test further?
Message 14 of 33
Nurlan-A.
We have the same problem. Revit crash when open a view.
Message 15 of 33
Viveka_CD
Hi @Nurlan-A.
Can you please send a journal and additional diagnostic data.
Let me know if you have any questions on how to find these files.
Message 16 of 33
bberggren
Central file in on LAN, latest Revit updates installed.
User opened Revit, created new local file and immediately tried to open plan view and Revit crashed.
Message 17 of 33
Nurlan-A.
This failure occurs on different computers. So far, we think that this is due to lack of memory.
Message 18 of 33
Viveka_CD
@Nurlan-A. and @bberggren
Does the crash result in a CER?
If so, can you please provide a CER number?
Message 19 of 33
bberggren
When this occurs Revit just shuts down.  No opportunity for a recovery file or anything.
One user crashed again this morning.  His computer has 123GB free on HD (500 total).
Physical memory was at 30% usage and Virtual memory was at 20% usage.  So I don't think memory is the issue here.
The only other programs running at the time were Chrome, Outlook, Bluebeam, Windows Explorer, and Skype for Business.  I have attached the journal file from this crash.
At least two others Revit users have experience this on this project.
Message 20 of 33
Nurlan-A.
Yes, we have the same situation, Revit simply closes without warning.
