Drawing a wide stair
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
998 Aufrufe, 5 Antworten
I tried to model a wide stair but keep getting the error that the the riser didn't intresect the boundary.
I tried to choose the boundary at the side of the stairs (the red circles) and the riser are the other lines.
How to do it?
Tags (2)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
I can't make that stair work in one sketch. I needed to break it up into 5 sketches joined together.
Nachricht 3 von 6
Nachricht 4 von 6
als Antwort auf: ToanDN
I didn't get it. Can u explain how u did it.Thanks.
Tags (2)
Nachricht 5 von 6
Create a stair then convert the run to sketch.  See file attached for run settings.
Nachricht 6 von 6
Corsten.Au
Just get a quick tutorial for stairs..
1. Riser ( black lines ) , this should touch boundaries
2. Run ( blue ) this should be continuous.. ( some exceptions in complicated stairs ), from first to last riser..
3. Boundary.. ( green ) this needs a bit of logic, boundary line exceptions are first and last riser lines...
go through this..
https://www.youtube.com/watch?time_continue=884&v=HqMhhOPluao
cheers
Corsten
Building Designer
