Revit 2019 Problem
5 REPLIES 5
Vasilii_Bogdan
431 Views, 5 Replies
Revit 2019 Problem
Hello guys, could you help me - I cannot draw floor in 3D in Revit 2019.
Please see attached screenshot
5 REPLIES 5
bin
in reply to: Vasilii_Bogdan
Top right of your image, do you see the Set work plane command? Use it to set your work plane to a Level.
Vasilii_Bogdan
in reply to: bin
Thanks so much, it woked!
What does it do Set Work Plane command - how do we use it?
Could you give some details?
bin
For example, you want to model in place a picture frame on your wall, instead of creating an extrusion from the floor, you can create it from the wall. Set the work plane on the wall and create the model. You may also want to draw some model line on some face, you need to set the work plane first.  It can also be useful if you want to measure in 3D View, for example if you want to measure the distance between the floor and ceiling, you need to set the work plane to a vertical face that perpendicular to the planes you want to measure. You need to set the work plane back to floor level if you want to model floor, roof, ceiling etc in a 3D view.
Vasilii_Bogdan
in reply to: bin
Great explanation! Thanks!
Do you know by any chance why I don't see objects below Second Floor, like
columns on a first floor etc.
I set View Range no the bottom, but still does no help...
I suspect the Column Category is turned off in the View.  You can quickly verify by clicking on Reveal Hidden Elements (the Light Bulb icon) on the View Control Bar at bottom.   If Columns show up in red, you can select one and click on Unhide Category, and then turn off the Light Bulb.
Forma Design Contest
Technology Administrators
