revit 2019 is freezing when is request to save works
Message 1 of 11
Please help me to find the solution to save my work and stop freezing my revit
Replies (10)
Message 2 of 11
Viveka_CD
Hi @Anonymous
Please, follow these steps and retest the behavior afterward:
  1. Close all Revit sessions on your computer
  2. Go to Windows > Start > Search field and type %temp%
  3. Hit Enter
  4. Clear all instances in the Windows Temp folder
  5. Skip all instances Windows reports to be in use
If clearing the Temp folder does not clear the issue, there are two more approaches to track down the cause of this error:
  • Check the Windows Error Report log (to see what Windows recorded as the problem).
  • Install last Windows Security Update
If the Event log shows the following entries, see this article: Error "Revit has stopped working" and then Revit 2017 shuts down
Faulting module name: RevitDB.dll
Exception code: 0xc0000005
  • Check the Revit journal file to see if it shows a problem prior to the error.
In some cases, the issue might be related to the Antivirus (Trend-Micro, Kaspersky, Sophos...).
Disabling or even uninstalling it could solve the issue.
If the steps above do not lead to a solution, cleanly uninstall and then reinstall Revit and follow the instructions highlighted in this article.
Looking forward to your reply update.
Message 3 of 11
Viveka_CD
Hi @Anonymous
It's been a while and I have not heard back from you.
I'm checking back to see if your issue is resolved and if you seek more assistance on this. If the issue persists, we can continue the conversation and feel free to unmark the solution.
Looking forward to your reply.
Message 4 of 11
patkson
Hi Viveka,
I have similar issue Revit 2019 crashes upon saving file for whatever reason and probably worse,
I have installed latest hotfix and update and add-in or extension form Autodesk. It just won't stop crashing and I can't work on my project. So frustrating, Infact the only feed back I get is first, Save "command fail",  And jext upon trying to save, the crash happens.
Please help
Thank you.
POK
Message 5 of 11
ari.monteiro
Hi @Viveka_CD!
I'm facing the same problem: SAVE command not responding in Revit 2019.
I posted in another topic: https://forums.autodesk.com/t5/revit-architecture-forum/revit-2019-not-responding-save-command/td-p/...
Since I did not get a response in this post, I decided to post my problem here.
I followed the procedures below to try to resolve the issue but did not succeed:
  1. Uninstalled Revit 2019 using the procedures on this the topic (https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...);
  2. Installed the latest updates of Windows 7 Ultimate SP1 64 bit;
  3. Installed the latest video driver update;
  4. Reinstalled Revit 2019;
  5. Installed Revit 2019.1 update.
Would you have any more suggestions?
Message 6 of 11
It worked for me by installing the "Revit 2019.1 Update" and "Revit 2019.0.2 Security Fix" updates, respectively.
Message 7 of 11
Viveka_CD
Hi @Anonymous
Thanks for getting back to us!
Glad to hear that this helped resolve your issue.
Message 8 of 11
Olá @Viveka_CD
Message 9 of 11
Viveka_CD
Hi @Anonymous
Please make a separate post and ping me @Viveka_CD
Message 10 of 11
Hi
i am having the same issue. Revit freezes when trying to save ANY model, even the SAMPLE. It is very frustrating, i am using student version of revit and was thinking about buying it, but now i have doubts, bacause NOTHING works.
This is the things i already tried:
1. Restarting computer
2. Reintsalling Revit (clean install). Even installed newer version 2019.
3. Cleaning temp folder
4. Disabling add - ins.
5. Installed latest windows update.
6. Checked for video driver update.
Everything works on other machine.
Message 11 of 11
Viveka_CD
Hi @Anonymous
Sorry to see that you are having issues with Revit 2019.
Please log a case with support, one of our specialists should be able to help you!
