Survey Point
Survey Point
mairh_tsek
Survey Point
mairh_tsek
Hello all,
Maybe a not so clever question..
Could someone tell me normally in a project from where we take the coordinates for the survey point?
It will be 0.0.0 or there is someone that need to give it's coordinates?
Thank you in advance!
cbcarch
The Survey Point is exactly what is says it is. If you have a Survey ( in Cad ) file, there will be a coordinate system used by the surveyor, with X,Y and Z points.
Link the Cad file into Revit. Then specify the coordinates for the Survey Point.
Check here:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
mairh_tsek
When I link in Revit a .dwg geopositioned, and Acquire Coordinates, I have the survey point in 0.0.0 and the project base point in a distance. It means that The survey point in Revit is the same with the Survey in CAD?
Thank you!
Thank you!
If you Acquired Coordinates; then YES, that is correct!
