Revit 2019 Crashes
Revit 2019 Crashes
Message 1 of 9
Revit 2019 Crashes
My Revit 2019 crashes when I tried to create floor boundary in a linked model.
I have updated the latest hotfix 2019.2.1 and Personal accelerator for Windows 10 but the problem still persist. Please help.
Thank you,
Akil
Replies (8)
Message 2 of 9
ennujozlagam
Are you creating the floor in link files itself or in the main drawing where your link file is a link? Have you tried to audit both files before linking them. Thanks
Message 3 of 9
I was creating the floor in the main file where i linked the models. Is audit meant for worksharing? I have not using work sharing for this. I am doing it locally myself.
Message 4 of 9
ennujozlagam
Audit function periodically to maintain the health of a Revit model, when preparing to upgrade the software, or as needed to locate and correct issues. The Audit function scans, detects, and fixes corrupt elements in the model. It does not provide feedback on which elements are fixed
can you untick your use hardware acceleration from options > hardware and see if helps. thanks
Message 5 of 9
it is still the same. what would be the other causes?
Message 6 of 9
ennujozlagam
unload your link file then create your floor, if you managed to create your floor without issues then reload again your linked file it could be linked files has the issues. thanks
Message 7 of 9
Matt__W
@Anonymous can you post a copy of the journal file after Revit crashes, for review?
REVIT: LOCATION OF JOURNAL FILES
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 8 of 9
Attached with the Journal files for 25th and 26th June 2019.
Thanks.
Message 9 of 9
Yes, the problem only appears when the user starts linking revit files. Without linked files, everything is just fine.
