I have designed a dwelling which is to be linked a number of times to the same site, but I would like to make each dwelling unique by changing some materials used in their curtain wall panels. Can this be achieved?
I think you can do so by adding all the different configurations in design options.
After that, you can change in your master file the design options per child-link.
Visibility settings > RVT Links > Display Settings to custom per child-link (not the parent link) > Design options > Change to custom > Choose your preferred design option.
Good thinking, but sadly because the curtain panels are contained in 'Curtain Walls' which are part of 'Walls', this is not practical as practically every external element of the building has to become part of the Design Option. Thanks anyway, much appreciated.
Well that is true, but it is the only way I can think of. Otherwise, you have to remove all the external walls from your linked file and only model them in your master model.
