Revit 2019 Crash Issues when Saving File
patkson
Message 1 of 9
patkson
Dear all,
I am continuously unable to save a model I have been working for long in 2019 environment. This has only been an issue in the 2019 environment. It starts load families normally but crashes upon on two attempts of saving model.
I find this a bit strange at this stage of revit development.  First attempt give failed command and second attempts takes you to save a recovery mode which then crashes later on.
What can I do.
Patrick
Replies (8)
Message 2 of 9
Viveka_CD
Hi @patkson
Did the crash generate a CER?
Did you try an audit?
You can send across a journal file to test further.
I can send you a private uplaod folder.
Let me know.
Message 3 of 9
patkson
Many thanks for responding, but its really getting frustrating for me on this, I have tried everything I know,  model audit, deleted temporal folder files. reinstalled revit and all add-ins. It still hasn't resolve the issue permanently, It gets resolved temporarily and allows saving for once or twice and crash. And no, it doesn't generate any cer, I only get first command fail at first, and then on second attempt I asked to save a recovery file which doesn't which fails also.
Please help.
Many thanks
Patrick
Message 4 of 9
Viveka_CD
Hi @patkson
Sorry that this did not solve the issue. I understand your frustration. I'd like to help you with this.
I'll need your file and journal along with the diagnostic data to troubleshoot further.
Please see article:  Revit - Collecting and sending diagnostic data to Autodesk Technical Support
Let me know and I can share a private upload folder if you'd prefer.
Message 5 of 9
patkson
Hi Viveka,
Appreciate your swift responses,
Let me know and I can share a private upload folder if you'd prefer. Yes Please.
I want to upload the model for your assistance.
Thank you.
Patrick
Message 6 of 9
Viveka_CD
Hi @patkson
I've haven't heard back from you in a while. Were you able to upload the diagnostic data to the shared link provided?
Let me know if you've had trouble accessing the folder?
Message 7 of 9
patkson
Hi Viveka,
Sorry for late response went offline for a moment, Yes I have resolved the issue by removing all auto-desk products plus addins, and  flashing of all records off the system registry. All alternatively reinstalling windows. Seem like a tedious process especially having to reinstall all programs back, but it got the job done.  Meanwhile I have sent diagnostic data to Autodesk.
Thank you.
Patrick
Message 8 of 9
Matt__W
@patkson this may indicate the presence of a corrupt family or families within the model. Please try the following steps to search for, and correct, any corrupt families within your project model.
  1. Open a COPY of the original model
  2. Save out the families. When Revit finds one that's corrupt, it will crash.
    https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
  3. Make note of the family that crashed Revit (the last family will be visible on the status bar in the lower-left corner)
  4. Close Revit
  5. Reopen Revit
  6. Open the central model from step 1.
  7. Delete the corrupt family from step 3.
  8. Save the model
  9. Repeat steps 2-8
  10. Repeat until Revit doesn't crash while saving the families.
  11. Get clean copies of the original families and reload them into the ORIGINAL model and overwrite the existing families.
It's essentially the same process as outlined in the Solution section of this AKN article.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Also, below are a few links to some additional resources to help troubleshoot a corrupt Revit model.
Autodesk University 2017 - BLD125158 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models Presentation
http://bit.ly/2BQ38qe Watch it at au.autodesk.com
Handout from my co-presentation and Datasets
https://1drv.ms/f/s!AmO3IjYenWEdhPYvoPS5MKqY9aSjeQ
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 9 of 9
Viveka_CD
@patkson wrote:
Hi Viveka,
Thank you.
Patrick
Hi @patkson
Thanks for getting back to us. Glad to hear that removing the add-ins helped resolve your issue:
How to disable add-ins for Revit
I will take a look at your diagnostic data and share updates.
