Revit Structural File Link - Joining Beams with your Slab
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
David_Knight
948 Aufrufe, 1 Antwort
So I'm curious.  How do you guys deal with  Structural Revit links when you own the slab and columns, but the beams are part of the structural revit linked model.
Example:
I own the concrete floor slab of a building were doing.  I also own the concrete columns (copy/monitored).  They clean up fine.  Concrete beams do not because you can not join these objects (they are in a link).  Nor can they be copy/monitored.  All materials are identical.
See 2 attached images for examples.
What I do now as a work around is to create a small "patch" of concrete hatch that covers it.   It's sloppy in my opinion.  But I have no other ideas how to work around it.
Thoughts?
1 ANTWORT 1
Nachricht 2 von 2
David_Knight
als Antwort auf: David_Knight
I was hoping the concrete hatch wouldn't be the answer. Smiley (überrascht)
