Revit 2018 wall top constraint issues
jstanulis
jstanulis
Revit 2018, I cannot change the Top Constraint of any walls, cannot change to unconnected, ans specify a height.  Problem persists on multiple files opened and on new walls or existing in the model.  How do i repair?
apurba
Please give a screen shot of your problem
Sahay_R
Sounds like the wall tops are joined to the roof. Select the wall. In properties, change top constraint to Unconnected. If this is not the case, then please share a file.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Viveka_CD
Hi @jstanulis
I'm checking back to see if there is any progress on your issue? Did the suggestion by @Sahay_R help resolve, if it did, please accept the solution.
Let us know if you need more assistance or have additional questions.
I'm having the same problem and my walls are not connected to anything.
@Viveka_CD wrote:
Hi @jstanulis
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community!
Can you please make a separate new post and I will follow up from there.
Please specify the version, and share a file or screenshot if possible.
