Revit 2018 Visual Problem
Message 1 of 26
I have a problem like in the below photo. Any suggestions ?
Replies (25)
Message 2 of 26
-FDC-
Graphics card driver.
What card do you have ?
Message 3 of 26
Viveka_CD
Hi @Anonymous
Do you have a multiple monitor setup? If so, disable and check the primary monitor.
Please try the below for me:
  • Check for latest updates from the Desktop App.
  • Disable Hardware acceleration and see if this issue persists.
  • Update you graphic card driver form the manufacturer's website.
Message 4 of 26
Viveka_CD
Hi @Anonymous
I just wanted to follow up here, any progress on this issue?
Let me know if you have additional questions.
Please mark any posts that help with "Accept as Solution" and thanks! Kudos welcome.
Message 5 of 26
NVidia Quadro P3000
Message 6 of 26
Viveka_CD
Hi @Anonymous
Please update your graphics card from this link
This may fix your graphic display issues.
Message 7 of 26
Hi @Viveka_CD,
I did what you recommend. Update drivers but the same. 😞 Should I try to install Revit again ?
Message 8 of 26
Viveka_CD
Hi @Anonymous
Try a repair first, it if does not work please try installing Revit again!
Message 9 of 26
-FDC-
Did you check if Revit is using the Quadro ?
-> File -> Options -> Hardware
Message 10 of 26
Viveka_CD
Hi @Anonymous
Message 11 of 26
No. Nothing changed.
Message 12 of 26
-FDC-
Did you check if Revit is using the card?
Is it a laptop or a desktop?
Message 13 of 26
Of course. Its a certified card.
Its laptop Dell 7720
#- Please type your reply above this line -##
Message 14 of 26
Viveka_CD
Hi @Anonymous
I'm sorry to hear that!
Can you please send me the recent journal file to test further? I can share a private upload folder.
Looking forward to your reply update.
Message 15 of 26
I can send tonight but i dont know what is journal file ?
Message 16 of 26
Viveka_CD
Hi @Anonymous
HERE is information on the location of the journal file.
I have just sent you a link to a private folder. Let me know if you have issues accessing the folder.
Please upload your journal and Revit model and I'll be happy to test it for you.
Message 17 of 26
-FDC-
That is not what I mean.
I have seen lots of people with workstations and expensive quadro's who are using the built in intel CPU graphics option.
It is perfectly possible that Revit is not using the quadro.
Check it please.
Message 18 of 26
Could you tell me the way ?
Message 19 of 26
-FDC-
File, options (see screenshot)
Then click hardware and look what Revit says at "video card".
Message 20 of 26
-FDC-
Did it help ?
