Revit 2018 units problem only metric display
In installed revit 2018 in this architecture temple metric units only display I want units in feet and inches how to change my units and also i check in template data only metric template available. To give solution for my problem
nmarcelis
You can change to imperial units by changing the defaults path to the template folder to the Imperial template folders. These are marked with an _I as a suffix.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Revit Certified Professional Architecture, Structure and MEP.
_Vijay
Hi @Anonymous , Try install imperials library from below link.
https://knowledge.autodesk.com/search-result/caas/screencast/Main/Details/a07881c2-c751-459e-bf1d-50...
for Additional content:  https://knowledge.autodesk.com/search-result/caas/screencast/Main/Details/a07881c2-c751-459e-bf1d-50...
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
