CAD import into revit changing the hatch pattern
_Vijay
_Vijay
I am trying import the CAD in to Revit Detail item family. but its not showing as same as in CAD file. I have added the image for the better clarification.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
hmunsell
i assume the view on top is Autocad and the view on the bottom is Revit? the dashed line for the callout, on the right, is not showing dashed int he the Revit view either. looks like it could be a View Scale issue. changing the view scale will of course effect your text though. the other option is to delete the imported hatch and replace it with a Revit hatch. those both look like fairly common hatch patterns.
Howard Munsell
_Vijay
I tried export in the can and import in to the Revit and  the problem solved.
Vijayakumar
Head of BIM
kevin_pluijmakers
Observer
Observer
Change the "psltscale" in the dwg file from "1" to "0" and it should be solved.
credits to "sbrown"
https://forums.augi.com/showthread.php?82831-AutoCad-Hatch-not-showing-up-in-REVIT
