I have created a toposolid from a CAD import but it is necessary to make adjustments because the generated triangulation is not the same.
It is annoying to edit a toposolid sketch boundary and lose all elevation points within the boundary. With toposurfaces we could add or delete points from surface regardless of the boundary.
Any thoughts on how to avoid this? I would like to create a new sketch or partially edit the generated one, maintaining all existing points.
