Revit 2018 - section callout heads missing?
sascari
Message 1 of 26
sascari
The callout heads seem to be missing from Revit 2018? Fresh install.
Replies (25)
Message 2 of 26
Are you sure they're missing, or just not defined under the "Symbol" parameter in the Level Type Properties?
Message 3 of 26
sascari
Good question. When I go to edit - type the symbol seems to be missing?
Message 4 of 26
Choose one from the drop-down list. You see one. No?
Message 5 of 26
sascari
The drop down is empty...
Message 6 of 26
odd. So you have none in Project Browser. Wonder what else you're missing? Maybe @Viveka_CD can assist here?
Message 7 of 26
sascari
Yea, that's a great question. This is a fresh install but our office doesn't typically use Revit. I'm helping with the transition. I'm sure I can always download a section family and add it but I'd like to work out from the system files...
Message 8 of 26
Viveka_CD
Hi @sascari
You have to load a Callout Head type.
After loading, Please go to your Manage tab, Additional Settings, Callout Tags. Let me know if this helps.
You can also create a callout head family
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Message 9 of 26
sascari
How do you load a callout head type? Is it not included with the default install?
Message 10 of 26
Doesn't sound like you can, if you don't have the library. Could be there, but just pathed wrong during your install of 2018.
But if you can find the library, you'd just load it into project like any other family. Still, I wonder if it wouldn't be better to a clean uninstall/reinstall.
Message 11 of 26
sascari
Could be...I've had to install a lot of additional content
Message 12 of 26
sascari
So, which library do I need?
Message 13 of 26
Sahay_R
Annotations
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 14 of 26
Viveka_CD
Hi @sascari
You have to load the family from Insert>Load family> Annotation> Callout Head.rfa or Callout Head w Sheet-Ref Sheet.rfa
Callout headCallout head
Let me know if you have any questions.
Message 15 of 26
sascari
Since they are missing, looks like i'll have to track down annotation system families and redownload?
Message 16 of 26
I don't think those are call-out heads in your photo. I think that's a Level. So, you would be missing a type of Level Head.
Message 17 of 26
sascari
You're right. It's both though. I meant to upload a different screenshot (see attached for section line).
Message 18 of 26
Viveka_CD
Hi @sascari
Yes, you have to download and install, since they are missing from your annotations folder.
Annotations are loadable families are created in external RFA files and imported (loaded) in your projects.
The below links represent the Family Templates, Project Templates and Family Libraries provided within the Revit 2018 product installation for all supported languages and locales.
To apply the content files:
  • Download the desired content executable to a local location
  • Launch the content executable from the saved local location
  • Specify the desired content location (Default destination folder “C:\Program Data\Autodesk\RVT 2018”) and choose Extract.
RVT2018_1_ENU_Imperial_FamTemplates_Templates (exe - 91MB)
RVT2018_1_ENU_Metric_FamTemplates_Templates.exe (exe - 110MB)
RVT2018_1_USA_Imperial_Libraries.exe (exe - 0.99MB) United States Imperial
RVT2018_1_USA_Metric_Libraries.exe (exe - 921MB) United States Metric
Let me know if you have additional questions.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.Kudos welcome.
Message 19 of 26
sascari
Hi Viveka,
I am installing the family libraries now. Will let you know if it works.
Message 20 of 26
sascari
Viveka,
the callout head shows up now. Do I have to load the family in each project?
