Revit 2018 - section callout heads missing?
sascari
Message 1 of 26
sascari
The callout heads seem to be missing from Revit 2018? Fresh install.
Replies (25)
Message 21 of 26
Yes. Additionally, you can add the family to an RTE so New Projects using that Template will have the family in it by default.
Message 22 of 26
sascari
Barth,
Thanks for the reply. So out of the box, none of the system components are usable in Revit? You have to manually adjust them?
Message 23 of 26
Some basic families should be included if you started from a Project Template.
Message 24 of 26
@sascariwrote:
Barth,
You lost me. If the family is loaded into the Project Browser, then you should have access to it. If it's loaded, but unusable; that's another issue.  And, what do you mean by "manually adjust them"?
Message 25 of 26
sascari
@ToanDN Thanks for the info.
@barthbradley I guess I meant if you had to load the family each time you start a new project (without a template). I'm learning that templates are crucial to the process.
Message 26 of 26
Every Project starts with a template (RTE).  Go to Options=>File Locations to see where the default templates are coming from.
...View Templates are a different animal
....https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/R...
