Revit 2018 on Windows 10 Bootcamp Print to PDF text OVERLAP issues...
Heritage_Architecture
Message 1 of 77
So I have spent the last week researching a fix for this problem... I am running Revit 2018 on a 5K Mac with Windows 10 installed on Bootcamp.
I am running with the Graphics Chipset AMD Radeon R9 M395X (Bootcamp XG edition by bootcampdrivers.com), because every time I tried to run the Mac Update on the Windows side to get the Bootcamp 6.0 Graphics Drivers Update, my 3 displays would all turn off and refuse to come back online after the download reached about 50-75%.
Everything pretty much works pretty well, (except the COINS plugin I tried installing today still won't load up?) but every time I try to print a sheet to a PDF (Adobe DC, Bullzip, Cutepdf, doPDF, etc...) the font that looked so perfect and readable on my display screen becomes bloated and overlaps itself, looking as if it has scaled its width 300%, both in print preview and the generated PDF... I really am at my wits end with this one, having tried to install the Windows 7-8 visual hotfix (which won't install itself in a Windows 10 environment...) that was said to correct a similar issue in Revit 2017 to no avail... I have also tried all of the resizing options with adjusting the text scaling and resolution to thei... without any success...
Please... if anyone can find a way around this problem please please please let me know.
Thanks.
Replies (76)
Message 41 of 77
brendan
I managed to update to the latest version of windows 10 (OS Build: 16299.309) and it didn't affect the text problem.
My text is still all messed up! 😞
Message 42 of 77
Viveka_CD
Message 43 of 77
Viveka_CD
Hi @brendan
Sorry to hear that you are facing issues with printing.
Can you check if you have installed the recent updates for Revit 2017 and 2018 from your desktop app?
Thanks for sharing your screenshot and system specifications.
We will also require your Revit file and journal log to investigate further. I can share a private upload folder if you'd prefer.
Looking forward to your reply update.
Message 44 of 77
Viveka_CD
Hi @brendan
Can you check the article by @michael_coviello and let me know if the solutions helped resolve your issue?
This issue is related to your AMD Graphics card.
Message 45 of 77
brendan
Hi @Viveka_CD. I followed the steps in @michael_coviello's article and it didn't help.
  • I'm using Revit 2017.2, but I've tested 2018 and the problem is the same. I'm not seeing any updates, so I believe this is the latest version.
  • My AMD graphics card driver is: 22.19.170.1536 and when I search for updates in the Device Manager it tells me that I have the most up to date drivers.
  • I believe my Windows 10 Home is up to date as well: Version 1709, OS Build 16299.309
  • I have set my scaling in Deisplay settings to 100% for this test.
  • I created a brand new Revit file with some text and a view on a sheet and made a pdf.
  • It appears that only text created with the text tool is distorted. Text created by labels such as in the view title family prints just fine.
  • The text issue is the same whether I'm printing to PDF or printing to a physical printer.
  • I've tested a few different fonts and it seems like the text distortion is the same regardless of font.
Attached are the files you requested. I created a blank file with a bit of test text in it rather than use one of our actual projects so we wouldn't have to deal with a private upload folder or anything.
Message 46 of 77
michael_coviello
Autodesk Support
Autodesk Support
Hello @brendan,   Please send an IM with your contact information,  I would glad to contact you to better understand this issue in context and to collect more information.
We'll be happy to log a support case and work with you towards a resolution.
Michael C
Technical Support Specialist
What's New in Revit 2023 | Autodesk University | Revit Blog
Message 47 of 77
I believe the original article you were trying to look at suggested rolling back your graphics card driver if it is already up to date.
*Edit: In fact, this was indeed the trick that finally fixed the problem for me a few months ago!
Message 48 of 77
brendan
@AnonymousThanks! That clue helped me fix the problem.
I just wrote out a reply and it got marked as spam, so I'm trying again with no links.
@michael_covielloyou might want to update that support article, because, at least for Bootcamp users, updating to the latest AMD drivers is not the solution.
Here's what I learned:
  • AMD Driver 22.19.170.1536 does not work (this is what I started with)
  • Rolling back to AMD Driver 15.200.1060.0 does not work
  • Installing AMD Bootcamp Driver 17.10 fails
  • Installing AMD Bootcamp Driver 15.201 works and fixes the issue!!!
  • Display scaling was a red herring for me. Now that I have the right driver, the display scaling doesn't matter and I can choose whatever scaling I like.
You will have to use google (try searching AMD Apple Boot Camp Software Graphics Drivers) to find that driver because posting the link appears to get caught in the spam filter. This is my working system now:
  • 5k iMac running Windows 10 via Bootcamp
  • AMD RADEON R9 M295X graphics card
  • Driver version: 15.201.1301.0
Downloading that specific 15.201 driver from the AMD Bootcamp drivers page was the solution. I am limited to 3840x2160 as that driver doesn't support 5k, but that's not the end of the world.
Message 49 of 77
michael_coviello
Autodesk Support
Autodesk Support
Thank you for the updates @brendan and @Anonymous
The older article has been reactivated.  The link may take some time to be 'live' and we will update based on this information.
I recommend logging a case with AMD as well (if you haven't already)
http://knowledge.autodesk.com/article/Revit-Text-overlaps-when-printing-or-print-preview-on-MAC-with...
We have seen occasions where rolling back the driver was not an option based on which Windows 10 updates have been installed.
I'm glad you got it working and thank you for the updated information.
Michael C
Message 50 of 77
Viveka_CD
@Anonymous Thanks for pointing that hint about the driver rollback!
@brendan Glad to hear that your issue is resolved!Smiley Happy Appreciate you getting back to us and letting us know what worked for you and what you've tried.
@michael_coviello Thanks again for the follow-up and reactivating the older article.
I've marked all your responses as 'accepted solutions' hoping this will benefit the community seeking solutions to similar issues.
Message 51 of 77
I have this issue on a iMAc Pro (2018) With Revit 17.3 as well  as Revit 2019
Display Scalingimage.pngimage.png is set to 175% also Resolution is set to 5120 x 2880
Message 52 of 77
brendan
@AnonymousHave you tried installing the Bootcamp AMD Drivers that fixed the problem for me? This is what worked for me: https://forums.autodesk.com/t5/revit-architecture-forum/revit-2018-on-windows-10-bootcamp-print-to-p...
The AMD Bootcamp Drivers version 15.201 is what worked for me, but your iMac is newer than mine, so I would try both the 15.201 drivers as well as the latest ones.
This is the AMD Bootcamp Drivers page: https://support.amd.com/en-us/download/desktop/bootcamp
Message 53 of 77
Viveka_CD
Hi @Anonymous
Can you share a journal file for each version? It will help us investigate further.
Let me know and I can share a private upload folder.
Have you updated to Revit 2018.3? DoDo you have multiple monitors set up?
Message 54 of 77
Revit 2017.3 and Revit 2019 are also having this issue on my machine ( We skipped 2018)
I tried changing the PDF printer.
Also we attempted to use a rolled back driver.
my machine is a 2018 iIMac Pro with Vega 56 Pro Graphics  on bootcamp
Is this an impassible error?
I loaded revit onto my surface pro 4 works WAY more efficiently. No Print problems even with the 4k screen.
Message 55 of 77
I have just the one monitor and we are using 2017.3 and Revit 2019.
I can share journal files if you tell me how to get to them,
Message 56 of 77
Journals Detailing 2017 and 2019 openings of the same file.
Message 57 of 77
@mshoffman @Anonymous I just wanted to emphasize that simply rolling back the driver one version does not seem to be working anymore. However, @brendan posted a very detailed solution where you have to uninstall your current driver and then reinstall  AMD Bootcamp Driver 15.201 (which is several versions back). Have either of you tried this?
I have had this printing issue happen twice now. The first time was back in November, and rolling back the driver one edition fixed it then. I then had it happen a few weeks ago (after @brendan posted his new solution) and his solution worked to fix it a second time for me. I haven't had anymore issues since (yet...) even though windows has updated a few times.
Message 58 of 77
I can't say for sure since I have AMD but it may be worth a shot.
Message 59 of 77
Viveka_CD
Hi @Anonymous
Thanks for sharing your journal files and screenshots, I've created a private folder and shared the link to your email.
Please check the below articles which provides solutions for compressed/overlapping font appears issues.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
We will also require results of this Collector Utility to test further.
Please upload this to the private folder, and let me know if you have trouble accessing the folder.
Message 60 of 77
Viveka_CD
Hi @mshoffman
Thanks for sharing your journal files with us.
Can you also share screenshots?
