Revit 2018 on Windows 10 Bootcamp Print to PDF text OVERLAP issues...
Heritage_Architecture
Message 1 of 77
So I have spent the last week researching a fix for this problem... I am running Revit 2018 on a 5K Mac with Windows 10 installed on Bootcamp.
I am running with the Graphics Chipset AMD Radeon R9 M395X (Bootcamp XG edition by bootcampdrivers.com), because every time I tried to run the Mac Update on the Windows side to get the Bootcamp 6.0 Graphics Drivers Update, my 3 displays would all turn off and refuse to come back online after the download reached about 50-75%.
Everything pretty much works pretty well, (except the COINS plugin I tried installing today still won't load up?) but every time I try to print a sheet to a PDF (Adobe DC, Bullzip, Cutepdf, doPDF, etc...) the font that looked so perfect and readable on my display screen becomes bloated and overlaps itself, looking as if it has scaled its width 300%, both in print preview and the generated PDF... I really am at my wits end with this one, having tried to install the Windows 7-8 visual hotfix (which won't install itself in a Windows 10 environment...) that was said to correct a similar issue in Revit 2017 to no avail... I have also tried all of the resizing options with adjusting the text scaling and resolution to thei... without any success...
Please... if anyone can find a way around this problem please please please let me know.
Thanks.
Replies (76)
Message 2 of 77
It's hard to believe but someone had fixed the same issue just by disable hardware acceleration.
Message 3 of 77
Sadly this did not fix the issue... I did however find out that if you have the Enscape addin installed, you have to disable THAT before you can even turn off hardware acceleration... otherwise Revit will not save your Revit.ini... very annoying...
Message 4 of 77
Sounds more like a MAC issue than a Windows or Autodesk issue.
Geez....Have a mac with 3 monitors and wonder why everything crashes when you are emulating a totally different software on a totally different operating system and blame the non-native software for the issue.
Buy a PC and call me in the morning.
Message 5 of 77
👍🏻 Go talk to my boss.
I'm tempted to mark this as the solution...
Message 6 of 77
Maybe you should remove all add-ons and plug-ins and whatnots and see if the problem persists.
Message 7 of 77
@Heritage_Architecture
Don't get me wrong....macs are great.  I know lots of RTC (BiLT) and AU speakers that use Revit on their Mac's all the time.
It just requires a lot more tweaking with the resolution and display scale to get it to work properly.
It's just finding that sweet spot is a PITA....
Message 8 of 77
BTW....Autodesk finally fixed the issue with 4k monitors.....ya got a 5k... gonna have to decrease that resolution a bit and not use the display zoom past 150%.
Message 9 of 77
Tried that already, no workey.
Message 10 of 77
matthewburr20
I know you said you tried to adjust display settings, but I just had the same issue and I had my settings for Scale and layout (size of text , apps and other items) at 150%, I just changed it back to 100% (recommended) and now the issue goes away and the text in my pdfs looks as it does on the monitor.
FYI, I had the same issue on my home computer (5k 27" imac, bootcamp, windows 10) and work computer (PC, windows 10) both running Revit 2018.
matt
Message 11 of 77
Just tried what you said...
But. No such luck.
The images in order:
  1. Screen Settings
  2. Screen Font
  3. PDF Font
  4. PNG Export Font
Hopefully you can see my predicament... now, if someone could just give me a solution...
Message 12 of 77
Share a screen shot of your advanced display settings for that monitor....
Message 13 of 77
We have the same issue occurring. It is NOT an issue with display size on screen, it is an issue in the Print processor. The text mis-scaling shows up in a Print Preview window, not on a normal display window.
The mangled text is then sent to the Windows Spooler and then to the printer (PDF or hardcopy) and the text prints mangled.
Hard to tell, but it looks like a horizontal scale factor of around 2.54 is being applied - I wonder if the OP is using metric like us? It looks a lot like a usual metric/imperial conversion SNAFU.
Windows set to EN-AU, Revit 2018.0.2 set to Metric.
Message 14 of 77
Using imperial... at least I'm not crazy, or alone... but we still have a
problem... 😞
Message 15 of 77
Viveka_CD
Hi @Heritage_Architecture
Sorry to hear that you are still facing issues.
Can you try the following for me?
Restart your PC: Windows needs the machine to restart after changing DPI, in order to print correctly.
Since you are on a Mac with Bootcamp, please see HERE for a resolution and install the RDP hotfix. (This fix applies to Windows 7 or Windows Server 2008 R2 for Remote Desktop Protocol)
See HERE for the Windows 10 RDP update.
Note: Regarding the issue with Mac/Bootcamp with 5K Monitor: Windows 10, the issue is under investigation for a resolution.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome!
Thank you,
Message 16 of 77
staynerarchitects
Observer
Observer
Has a fix for Windows 10 been issued?
Message 17 of 77
I don't know specifically about a Bootcamp installation (I don't have a Mac) but the issue on Windows 10 is resolved by patching Revit 2018 to version 1.1 or above.
Version 2 (2018.2) is the latest version available.
Message 18 of 77
Is there a new resolution? I'm having the same issue, and it started about 2 weeks ago, around when I updated Windows. I tried reverting back to the previous version of Windows 10, but the issue persists. I am running Revit 2018.2 on Bootcamp.
The overlapping text appears after exporting to PDF on all Revit files on my own computer, regardless of print driver, but it does not happen to any files on a coworker's computer (running Revit LT on Parallels).
Message 19 of 77
I am having the exact same issue.
Message 20 of 77
Here is a Autodesk Troubleshooting post on the subject. It suggests: "For users working on Bootcamp they will need to run Revit parallel."
Revit - Text stretched when printing to PDF
Switching to working in Parallels on the mac side didn't fully fix the problem, just made it not as bad. I have attached images of the three different outputs from three different combinations of machine/software. Both my coworker and I are using the same version of Parallels on a 5K iMac running Sierra.
