Revit 2018 on Windows 10 Bootcamp Print to PDF text OVERLAP issues...
Heritage_Architecture
Message 1 of 77
So I have spent the last week researching a fix for this problem... I am running Revit 2018 on a 5K Mac with Windows 10 installed on Bootcamp.
I am running with the Graphics Chipset AMD Radeon R9 M395X (Bootcamp XG edition by bootcampdrivers.com), because every time I tried to run the Mac Update on the Windows side to get the Bootcamp 6.0 Graphics Drivers Update, my 3 displays would all turn off and refuse to come back online after the download reached about 50-75%.
Everything pretty much works pretty well, (except the COINS plugin I tried installing today still won't load up?) but every time I try to print a sheet to a PDF (Adobe DC, Bullzip, Cutepdf, doPDF, etc...) the font that looked so perfect and readable on my display screen becomes bloated and overlaps itself, looking as if it has scaled its width 300%, both in print preview and the generated PDF... I really am at my wits end with this one, having tried to install the Windows 7-8 visual hotfix (which won't install itself in a Windows 10 environment...) that was said to correct a similar issue in Revit 2017 to no avail... I have also tried all of the resizing options with adjusting the text scaling and resolution to thei... without any success...
Please... if anyone can find a way around this problem please please please let me know.
Thanks.
Replies (76)
Message 21 of 77
So if it still does not work on Parallels properly I wonder what the solution is?
Message 22 of 77
I wish I knew. I was able to print correctly from a second coworker's computer who also has Revit LT on Parallels. However, when I tried Revit LT on my own computer, both in Parallels and in Bootcamp, the problem was still happening. I think that both my coworkers have the non-updated version of Windows 10, so that seems to be the issue with my own computer.
Message 23 of 77
Yes the Windows 10 upgrade is the problem.
My MAC with Bootcamp and Windows 10 worked perfectly until Windows 10 did an automatic upgrade, now it does not work.
I am going to try and see if I can remove the upgrades or reinstall Windows 10.
Message 24 of 77
I have reinstalled Windows 10 and REVIT 2018 and still no luck.
Message 25 of 77
See attachment of text.
Message 26 of 77
Same problem here, haven't seen a solution yet, Windows 10 updated today w/o asking me, and now I can't print anything. R18.2, Windows 10, Bootcamp, iMac 5k. Was working perfectly this morning. Need to print CD's stat!
Message 27 of 77
Also, Revit 16 is still printing fine. Unfortunately, our latest project has already been upgraded. Please help!
Message 28 of 77
I suspect that's more a Bootcamp / Mac / Windows thing than a Revit one.
The Windows 10 Fall Creators update has broken a lot of things in a lot of software.
Message 29 of 77
MikeMorrisonArchitecture
OK - same issues Revit 18.2, bootcamp etc. printing to pdf looks the same. If I export the drawing as a Dwg, open in Autocad and then print to pdf the text is correct. This seems to indicate it is a Revit problem, not Windows
Message 30 of 77
I wish there was a way to un-solve this! It has REALLY become a problem.
Schedule text, and some other parameter-generated text is still unaffected.
Message 31 of 77
Hi All
I am working on iMac 5k with Bootcamp and Windows 10.
The problem only started happening once Windows 10 did an automatic update.
I uninstalled Windows 10, reinstalled it and turned off automatic updates before I connected my iMac to internet.
I then reinstalled Revit 2018 and it is now working perfectly.
This shows that it is a Windows 10 Update problem.
Message 32 of 77
Viveka_CD
Hi @Anonymous
Thanks for sharing the update!
While this issue is under investigation by the team, your update will benefit other users.
Message 33 of 77
michael.coviello
Autodesk Support
Autodesk Support
Hello @Anonymous
The Windows update may be including an incompatible update to the video driver.
Please let us know if this article helps.
Revit - Text overlaps when printing or print preview on MAC with Bootcamp
Is anyone experiencing a problem other than overlapping text characters?
Thank you!
Michael C
Technical Support Specialist
What's New in Revit 2023 | Autodesk University | Revit Blog
Message 34 of 77
Nailed it! Thanks for your help.
Message 35 of 77
Worked a charm thanks very much
Message 36 of 77
Viveka_CD
Hi @Anonymous and @MikeMorrisonArchitecture
I'm glad to hear that this helped resolve your issues.
Thank you, @michael.coviello
Message 37 of 77
johnandrade
I think that you have some kind of trouble withs mac, when you can afford one then you can talk, I have PC, and mac working together and the only issue is print to PDF from revit on mac,  all my others DELL WORKSUPERSTATIONS PC have a lot of issues on others things... We have bootcamp thar only emulate the bios, all the hardware is the same than a DELL, try to be informed before write something.....
Message 38 of 77
brendan
Hi @michael.coviello believe I am having the same problem that @Anonymous was having. The link in your reply that seems to have helped other users leads me to a "Page Not Found" message. This is the link I am trying to follow: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Revit-Text-overlaps-when-printing-or-print-preview-on-MAC-with-Bootcamp.html
Any advice?
Message 39 of 77
michael.coviello
Autodesk Support
Autodesk Support
Hello @brendan
This article has been superceded.
For the latest information on this issue, Please refer to this article.
Current Status: This incident is being investigated for a possible cause and resolution.
Text shrinks when printed from Mac/Bootcamp with 5K Monitor: Windows 10 - DPI Scaling greater than 1...
If this does not apply to your situation or if the listed workarounds do not work, please share details including your Video Card/Driver version and a screenshot of what you are seeing.
Michael C
Message 40 of 77
brendan
Attached is a screenshot of what I'm seeing.
5k retina iMac running Bootcamp (from 2014 I believe)
Windows 10 Home Single Language
Version 1709
OS Build 16299.15
Graphics Card: AMD RADEON R9 M295X
Driver Version: 22.19.170.1536
We're still using Revit 2017 on our projects, but I tested Revit 2017 and 2018 and have the same issue in both.
Changing the scaling in Display Settings to 100% had no effect on the text issue.
I previously was on Windows 7 and everything was fine, and I just updated to Windows 10. The text issue began when I updated to Windows 10.
I am also having an issue where I can't install "2018-03 Cumulative Update for Windows 10 Version 1709 for x64-based Systems (KB4088776)".
