Revit 2018 No material browser
Message 1 of 69
I just startet using Revit 2018, student version. Have not tried revit before.
I found out that the material browser does not work. I cannot open the browser at all (Manage/Materials) or change any materials by using "Edit type"
Tried to repair and uninstall the Material Library but that did not work. Then I tried to reinstall the entire software. That did not help either.
I have looked at the File/options/File location, and it is the right path.
(As I know very little of software, I do not know if this information will help. But when I look at my computers local disk (c:)/Program data/autodesk/rvt 2018/librarys/Denmark and chose any of the folders there is a lot of rfa files. If I go throug revit/options/File location and choose the path, there are no files in the Denmark subfolders)
Hope someone can help me.
Replies (68)
Message 61 of 69
Sounds goodSmiley Happy
But how do I do it the right way.
  • First uninstall something?
  • Then install the other driver?
  • Then install revit 2018?
Hope someone can tell me.
Message 62 of 69
Hello to you all.
Today I am very happy. Now everything works just the way it is supposed to:-)
I made a clean uninstall of the Revit 2017.
Then I downloaded the driver (353.62 version) that ToanDN recommended. After that I tried to install Revit 2018. Once again I could not install the material library.
Then I made a clean uninstall of the 2018 version, and tried to download it again to the browser. It looked like the material library was ready to download. But after I started downloading I got warnings about som temp.files missing, and nothing actually did download to/install on my pc.
I was a little frustraded...
I chose to reset my pc. After that I tried once again.
Downloaded the driver og then Revit 2018 to the browser.
And thats it. It all seems to work now.
A big THANK YOU to all you guys who kept going and actually solved the problem. I am very greatful:-)
Message 63 of 69
morehead
Delighted for you jelipandro - you might notice other improvements too 🙂
Message 64 of 69
jcosme
Congratulations, you worked very well.
Message 65 of 69
Hello!
I've been fighting thru the same problem of many people and finally I found also my direct padron problem!
I uninstalled and installed in many different ways and saw many versions but finally I ended up in the option that I could turn on JUST the CPU graphic driver!
And suddenly worked!
So there is for sure a problem with my Nvidia driver
(GeForce 610M)
Finally I can now see the materials and later I will try to find a solution about the other graphic board...
Hope I could help with some solution that might show up in the next updates because with Revit 2017 I haven't that problem so besides a problem with my driver (probably) there's also a compability with Revit 2017 which doesn't appear in Revit 2018.
Best Regards!
Message 66 of 69
Hi there
Has this issue been resolved?
I have the same issue, material browser is visible but nothing happens when i click on the ...
This happened after i updated to version 2018.3 on my Dell Precision notebook with M1000M graphics.
On my Dell Precision Dekstop PC i did not update and its working fine.
Tried 2018.3.1 but install failed, claims product is up to date
Disabled graphics, now i get a unrecoverable error the minute i open any Revit project.
Any way i can uninstall 2018.3 update?
Message 67 of 69
Solution
What I have come across and from reading in the forum the graphics card seems to be the main culprit.  If i disable my Nvidia Quadro 1000M on my Dell Precision M4600 and run the intel 3000 then Material browser works.  I have been trying to find earlier driver that works but auto updates from Microsoft is my next challenge.
Message 68 of 69
SL-Gh
I had the same problem but was resolved in the new 2019 release
Everything works good
Message 69 of 69
Viveka_CD
@SL-Gh Thanks for getting back and letting us know!
