- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there,
I'm having issues with floor editing freezing Revit. I'm not getting any warnings but unable to close out of the floor editor so have to end process in Task manager. I've also just had the same freeze happen when simply in the type editor changing a layer thickness of a floor family.
Screenshot shows the simle chage I was making to the floor thickness changing the topping thickness from 65 to 75 and boom locked up.
There was a previous post that suggested the hotfix fixed the issue, but it hasn't in my case.
Is anyone else having this issue even with the 2018.0.2 Hotfix installed? It's very frustrating having top redo work, so now need to make sure I save before I edit anything.
Does anyone have any fixes for the problem?
Cheers blairmack.
