Energy simulation results dose not change when I change the parameters.
2 ANTWORTEN 2
Nachricht 1 von 3
myounis4
348 Aufrufe, 2 Antworten
I am running my model on Revit 2016 to compare the energy simulation differences according to new parameters' values. For example, I changed windows size to be bigger (double).Unfortunately, after each run, I am getting the same energy simulation results in everything (including WWR ratio).
Any ideas why the energy simulation does not changed according to the new parameter value ?
Muna
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: myounis4
Nachricht 3 von 3
myounis4
als Antwort auf: ToanDN
Thanks for the answer. I have done this step before and it did not work. when I changed any parameter, I have two result scenarios:
1-  energy simulation results doesn't change at all.
2- minor change (almost nothing) for example: changing the walls material from insulated to be uninsulated, will produce only 1,000 $ for the total life cycle cost !!.
any other suggestions.
