Hi @Anonymous
No worries, both your messages are saved and I hear ya
Great to hear that downsizing your 3D Model from 10MB to 2MB helped resolve the issue! As recommended earlier before exporting a Revit model, it is highly recommended that we limit model geometry to improve the performance of the export process.
I also suggest you take a look at the model performance technical note HERE
It is likely that you will experience loss of data during an export.
Since you mentioned a few issues related to loss of structural framing post export, it is recommend that you modify settings on your Solids tab as follows:
- Open the 3D view of the project to export.
- Click File tab
Export
CAD Formats
(DWG files).
- In the DWG Export dialog, click
(Modify Export Setup).
- On the Solids tab of the Modify DWG/DXF Export Setup dialog, select Export as AutoCAD Architecture and AutoCAD MEP Objects.
Note: This option and the Prefer drop-down referenced in the next step are only visible if the ExportACAObjects key is present in the Export section of your Revit.ini file and is set to 1.
If you want the exported DWG to keep its structural properties intact, select AutoCAD Architecture objects, on the other hand if you want to maintain the geometric accuracy, select geometry.
- Regardng your zoomed out viewports, please try changing the UCSFOLLOW system variable setting to '0' in AutoCAD
I understand that Revit 2017 export capabilities worked fine for you compared to Revit 2018. We will test export capabilities in Revit 2018 and troubleshoot for errors.Thank you for posting about this issue in the forums. I have logged this issue with the development team for further investigation. Please do not hesitate to reply to this thread with any additional questions you may have in regard to this issue or any message that you want me to share with development that we haven’t already discussed.
You are also welcome to contact the product team directly. If you have additional comments specific to the software or its functionality for future consideration, please use the Product Feedback page. How to provide feedback on Autodesk products goes into more detail.
Please accept as solution if my post fully solves your issue, or reply with additional details if the problem persists.
Good luck with your projects!
