Hello!
Has anyone developed a checklist for upgrading projects to 2017 - the text changes can be extensive in a fully annotated project and I am curious if anyone has created a checklist to help PMs comb through their projects? I did make a quick scale factor cheat sheet (example below).
Solved by Viveka_CD. Go to Solution.
It's awesome to note that you are a Revit enthusiast! Thanks for your participation in the community!
Thanks for sharing the 'quick scale factor' sheet with the community.
Some new and changed features of Revit 2017 result in certain behaviors for upgraded models.
It is highly recommended that Project Managers/ BIM Coordinators review information on the following features before upgrading your models:
I also recommend checking out this awesome post on upgrade issues by @m.voss.alvine where he specifically talks about fixing missing phases during upgrade.
Now let's check out the above 9 features in detail:
The method for measuring text size is changed so that the Text Size parameter more accurately represents the height of a capital letter (similar to AutoCAD). Previously, Revit measured the size of text from the font baseline to the ascender line. Since most characters do not extend to the ascender line, physically measuring the font may not have produced expected results.
The size of text now reports using the cap height, which measures from the baseline to the top of a capital letter M. It is important to note that many Asian characters are somewhat taller than the capital letter M, so these characters appear taller than the Text Size parameter value for Western fonts. Adjust the Text Size parameter to make these characters the desired height.
This change affects all text in Revit. After upgrading a model, please review all views and sheets to verify the changes to your text instances.
The behavior of additional contours is improved to adhere to the Additional Contours specifications in the Site Settings dialog.
Previously, additional contours started at the bottom of the toposurface regardless of the Start or Stop settings. As a result, when you upgrade a model, existing toposurface objects are not regenerated; the post-updated model looks the same.
However, the first time the toposurface regenerates, such as when you edit the boundary or perform other related operations, Revit uses the new contour behavior. If desired, you can adjust the start range for the Additional Contours settings to achieve the same visual effect as the pre-updated model. See Define Site Settings.
The behavior of keynote legends is improved. When a keynote legend is set to By Sheet, Revit takes into account whether a keynote is visible in the view as a result of View Range settings, Design Option settings, or Depth Clipping/Far Clipping settings.
Previously, keynote legends listed keynotes that were not in the view because they were outside the view range, in a different design option than the one currently displayed in the view, or outside the view's Depth Clipping/Far Clipping range.
When you upgrade models that have keynote legends By Sheet, ensure that they display correctly. Note that a legend may have changed because it does not display keynotes that are not within the view range, depth clipping, or design option of the views on the sheet. See About Keynote Legends.
Enhancements to railings required changes to existing functionality. When you upgrade a model, railings hosted by floors will likely be slightly altered, as will railings sketched outside a host.
After upgrade, inspect all views to verify changes to railings.
The new structural connection feature introduced in Autodesk Revit 2017 does not overwrite legacy connection elements in upgraded models. Older connections will need to be replaced with the generic or add-in connections to be accessed by the new tools. See Structural Connections.
When you upgrade models, render settings defined for the NVIDIA mental ray engine are mapped to Autodesk Raytracer settings to achieve a consistent rendering output. Settings specified in the model for the Autodesk Raytracer rendering engine are not maintained during upgrade.
You must define these settings upgrading a model to Autodesk Revit 2017. See Upgrade Mapping for Render Settings.
When you upgrade Autodesk Revit 2016 models to Autodesk Revit 2017, the model category for fabrication parts changes from a single Fabrication Parts category to separate categories for MEP Fabrication Ductwork, MEP Fabrication Pipework, MEP Fabrication Containment, and MEP Fabrication Hangers.
Existing fabrication parts schedules that contain ductwork are reused for MEP Fabrication Ductwork. Pipework, containment, and hangers in those schedules have been removed.
Existing tags for duct are reused as ductwork tags. Pipework, containment, and hangers tags have been removed.
New setting: DisableCaBaGGe_3. Disables the CaBaGGe framework, which improves the performance of Revit when navigating views. See Misc Settings in Revit.ini.
For server-based workshared projects, see Video: Model Upgrade Workflow for Revit Server for recommended workflows and best practices.
For file-based workshared projects, consider the following:
If you link a workshared project to another Revit model, upgrade the workshared (linked) project before upgrading the host model.
If the host model is linked to a local copy of the workshared project rather than to the central model, the best practice is as follows:
To upgrade a workshared project to the current release of Revit, you only need to upgrade the central model.
The backup copy is for use only if the upgraded central model becomes corrupted.
The central model is upgraded to the new release. Depending on the size of the model, this process may take some time to complete.
Please mark this response as "Accept as Solution" if it answers your question to benefit others users seeking similar soltuions. Kudos gladly accepted.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
