Hi
Don't know if its a fixable issue or a 2018 issue, but now im trying.
When I have a groundplan and uses nested "generic annotations" in families, they disappear when applying "Color Scheme".
Any ideas? or is it a known issue?
Thanks in advance ![]()
Gelöst! Gehe zur Lösung
Gelöst von treyk. Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hi @Anonymous
A nested generic annotation is used to report a parameter or to show a text.However the text cannot be filtered out in your project, only an entire generic annotation can be filtered.
To assign a color scheme to your annotation family follow the steps below:
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi Viveka
It was not quite what I was searching for
but thanks for the post, it was helpfull in other ways.
My issue is that the text disapears when I apply a color scheme.
And when you highlight the family you can see the text and the box around it ![]()
This isn't unique to Revit 2018. I can reproduce the problem in both Revit 2017.2 and Revit 2018.
Hi @cadmanager
I'm glad to hear that my post was helpful.Thanks for sharing the image, that explains the issue better.
To try to fully solve your issue,please modify your settings based on the following options:
1) In the view properties "Color Scheme Location" set to "Background"
2) Change your "Model Display" property to "Hidden Line"
3) To modify the order of items
Scheme panel
4) To modify the graphic appearance of legend swatches
Scheme panel
5) To change the legend title
Scheme panel
6) To show or hide the legend title
Properties panel
7)If you created a text note
Please mark this response as "Accept as Solution" if it answers your question to benefit others users looking for similar solutions. Kudos gladly accepted.
Viveka CD
Hi FRB_HC--
This is a good catch! It seems that there's an issue with the draw order for Nested Generic Annotations (in families other than another Generic Annotation, for some reason) with respect to Color Fills. Taking a look at it now, and we expect to get it into an update release soon.
Trey
Hi @treyk
Thank you for looking at this function!
Controlling the layering of filled and masking regions in nested generic annotation families will be great add-on function through a draw order.
Viveka CD
Hi @Anonymous
We wanted to check back in with you on this post. How is everything working out? As mentioned before, I would be happy to take a look if you would like to post a sample file for troubleshooting. Please let us know if further assistance is needed from the community on this post. We are happy to help wherever possible. Thank you and we look forward to your reply update.
Viveka CD
