Revit Architecture 2016 Autodesk seek problem
Autodesk seek not found when I attempt to load or even look in seek. Message same not found. Any help would be appreciated.
Looks like the redirect isn't working anymore.  seek.autodesk.com should take you to bimobject.com but it isn't.
Just go to bimobject.com instead of the link through Revit.
I found that and downloaded it. it nested on the ribbon, but only seems to have commercial grade European companies. Did I load an incorrect type of BIMobject?
It may go by where you are located....
Try http://bimobject.com/en-us , if you are looking for NA items.
BTW....looks like the redirect is working again.  I just tested it here at work and it switches me over to the bimobject site.
Viveka_CD
Hi @Anonymous
You can download for specific regions.
See image below:
Best Regards,
