edit boundary from wall by face
I want to change my boundary line that i created by wall by face.
But i dont get the button to click on edit boundline (see print screen). The weird thing at 2 of my walls it is possible to do. And i made them al at the same time.There do is a button -> update to face. I try it out but no reaction.
Suggestions?
@Anonymous
If the face hosting the wall is not absolutely planar (warped) then you cannot edit the wall profile.
Do you have any suggestions to resolve this issue?
If the intention is to have a flat wall then fix the mass so that the surface is truly flat. On the other hand, if the non flat surface/wall is indeed desired, then use a void to cut the wall, or draw reference planes present the cut boundary and attach the wall to them.
